08-08-2023, 11:11 AM
I have a Ever Ready Sky Queen radio on the bench. Serial number Q770408. Looks to be an early Mk1 type with the basket weave speaker grills on both sides.
Arrived with a home brew battery eliminator installed -- badly. I sorted that and made it safe. Filament voltage a bit high so a resistor in series just to be sure that the valves survive. The valves have probably been over run. All the filaments are still there.
The radio doesn't work, no surprise, its 70 years old.
No audio at all, power is getting there and the output transformer is OK.
So I check around the output valve, utter confusion, it is not wired for the correct DL96 valve but for a DL92.
The paper label in the cabinet says DL96, all the other valves are Dx96 series. Looks as though it has never been altered or repaired from new. All the old caps are present.
But, yes, a DL92 is fitted. A Mullard one. The others are Ever Ready.
I think it is no emission, it has both halves of the filament.
Has anyone come across this use of this wrong valve from new before? Did Ever Ready run out of DF96 valves?
Boater Sam.
