28-04-2023, 09:27 AM
(This post was last modified: 28-04-2023, 09:41 AM by Radio Fixer.)
Should have done this years ago ! Its spring time and clearing up.
Always use Silicon Rubber Insulated Wire from Phil Marrison who has a stall at BVWS Swap meets He will supply by post if you dont get to those. ( Message me for his E-mail if you havent got it ). Its easy strip and doesnt burn with the soldering iron.
Current offering is 0.5mm sq and 0.75 sq with current ratings of 3A and 4.5A. I use the thin for general radio wiring and the the thicker for heaters, earth and HT.
I had the wire up until now just chucked in a box in a huge tangle. It actually degrades it because getting a straight piece isnt easy and sharp kinks dont really come out. So having bought some new stock I made the wire rack.
The key here is the beautiful NEW spools:
PLASTIC SPOOL PLASTIC BOBBIN ABS 100mm x 100mm x 63mm x 16mm, Plastic Bobbin | eBay
At a sensible price and low postage.
Note that I have put two wire colours ( resistor code
) on each spool. These come with two holes, top and bottom of each spool face, that pass 16 swg tinned copper with through nicely. A short piece of this is bent through this, and turned over on the outside, to make a flat loop that holds the wound wire at start and end. I used some 8mm threaded rod that I had as the spool supports but 15mm copper pipe would also work with a Jubilee Clip each end to fix it.
Thought possibly some Members might be interested
Gary
) on each spool. These come with two holes, top and bottom of each spool face, that pass 16 swg tinned copper with through nicely. A short piece of this is bent through this, and turned over on the outside, to make a flat loop that holds the wound wire at start and end. I used some 8mm threaded rod that I had as the spool supports but 15mm copper pipe would also work with a Jubilee Clip each end to fix it.Thought possibly some Members might be interested
Gary
