21-04-2023, 02:03 PM
In the absence of a valve tester how do you test a rectifier such as EZ80 or GZ34? Obviously if it works in a set then it's probably OK but I'd like to get some idea of how to measure it. I have LT and HT PSUs, plus several meters. I've tested triodes against the data sheet like this and could, if I was feeling patient, plot a set of curves.
Obviously I can check the heater, HK insulation and reverse breakdown. Though I wouldn't push that to find out how many kV it would take to make a GZ34 flash over
That leaves emission, and balance between the two halves. I can conenct a low voltage PSU, wind it up and find the maximum current the cathode will give. Not sure that's very good for the valve.
Any thoughts?
Any thoughts?
