18-03-2023, 07:25 AM
This was a player that was passed to me and I was originally passing on for donations to charity, but without success. So after sitting there for a while I decided to have a look at it.
The main ca,s that select FF, RW play etc seemed to be fine, there is an issue in that the right speaker provided no audio out, although the VU meter would move. It turned out that the speaker was open and this I believe was down to a broken fuse holder meaning one side of the split power rails was missing on the right amp and it would have fed 20 Volts DC to the speaker.
The capstan Spindle sleeve is missing, but I think I could make one of them.
There is however one thing that seems to have me stumped, and that is a cam under the record/play heads that lifts and lowers the erase heads, made of some form of Zinc alloy? It appears to have been forced or over tightened at some point and has broken the cam.
Repairing this I think is out side my capabilities, it is marked as M9-011i 4T cam in the service manual. I doubt very much I could weld it up and it is a bit complicated for fabricating another one. So if anyone can suggest a way forward to repair this machine it would be appreciated.
Adrian
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
