15-02-2023, 11:43 AM
The first attachment shows a recently repaired Bush TV22 connected to the modulator unit and my Pineapple field store converter along with a 625 line Test Card C generator which bought some twenty years ago from HS Publications.
The converted 405 video output will be connected to a modulator which was built around the David Looser circuit which appeared in the August 1984 Television magazine.
The owner of the Bush TV22 also owns a Pineapple converter which was fitted into an instrument case along with a modulator which may be recognisable to some forum members.
See second attachment.
The integrated circuit which was a surface mounted device had failed and it wasn't possible identify it's type. What we do know about the circuit design is that the IC was intended for negative modulation systems with intercarrier sound. In fact the AM sound carrier was generated by a 3.5Mhz oscillator and mixed with the baseband 405 line video. Performance of this modulator was never satisfactory because intercarrier sound is not suitable for positive video modulation systems because of the interruptions to the carrier signal during the period when the synchronising pulses are in the video signal. Intercarrier sound is possible with negative modulation systems because the signal carrier does not go down to zero or near zero level.
Both Pineapple converters are working very well. As for my clients converter, this will be used along with the Bush TV22 and the modulator which accompanied the TV set.
Geordie McBoyne.
Geordie McBoyne.
