31-12-2022, 09:12 PM
I'm not sure which section this really belongs in because the panel is not in itself electronic, although it might have been used for communications equipment. OTOH it could have been anything battery-related, but probably WW2-era War Dept issue. It is a panel maybe 18" wide, with four snap-action rotary switches, I think double-pole and probably rated at 15A, connected to various terminal studs. There's some kind of identification engraved at the top but none of my pics show it legibly. The switches seem to be marked 'Charge Batt No.1', 'Charge Batt No.2', 'Batt on charge from:' and 'Set supply from:' I originally thought that the word 'set' in the latter referred to a communication set or similar, but of course it could just mean 'Select supply from.' The only terminal markings I can read are the two in the middle marked '12V output.'
My experience of them has been through the electrical equipment of fairgrounds. Back in the 1970s there were probably hundreds in use by showmen as general-purpose switches for 110V DC. The one in the pic here is hung in a side stall, with the feeds to the lighting of adjacent stalls fed through it. There are not so many around now, particularly as 110V DC is in ever-decreasing use. Looking back at my pics of the fairground rides at Great Dorset Steam Fair 2018, I spotted three of them still in use although one partially dismantled, which piqued my curiosity as to their origin.
