19-12-2022, 03:46 PM
Today in the workshop I turned my Tektronix 585A on to monitor an oscillator on the bench, no sweep, odd. I then tried my Tek 545B, turned it on, no sweep, odder & odder, both were working fine yesterday.
As you all know we've had a prolonged cold spell recently, today the weather is a lot warmer. I noticed all my cables felt "greasy" to the touch, high humidity?
The only explanation for both Tek 500 series scopes going gaga is high humidity and the possibility that some valves in the scopes have died: my workshop is essentially a lean to on the house, no heating, I've noticed valves in scopes stored in sheds have gone to air, possibly caused by thermal expansion & contraction due to the cold.
Has anyone had similar test gear issues recently?
Andy.
Andy.
