10-05-2022, 09:05 AM
Perhaps this is an Irish model. Put in an Irish attic over 40 years ago.
It's like a Pye P76F in appearance https://www.radiomuseum.org/r/pye_p76fp_76.html but has no frame aerial. PE77 may be a similar chassis.
LW, MW and six SW bands.
Metal speaker grill which is common on the Irish versions.
The mains transformer primary and audio transformer primary both have reasonable Ohms readings so I agreed to "get radio working". Cleaning up the case a bit will be the owner's job. It was his grandfather's set.
