07-05-2022, 06:44 AM
This arrived on Thursday from a nearby person.
There are two versions of the German model, one with an EC92 and one with ECC85, this model has the ECC85. Main differences seem to be the extra pilot lamp to either indicate MW & LW, or that the ferrite rod aerial is in circuit.
A burnt wirewound resistor and a small pilot bulb rolled out when I set it on the kitchen table while I went to clear a space.
I started at 7 pm last night.
Loads of paper caps. One was crisped and had a 25 Ohm resistor beside it to chassis. The cathode of EL84? But no it was the screen grid pin 9. Pin 3, cathode, had the correct 170 Ohms. So I removed it as it couldn't be right. That's an HT rail.
Replaced 6 paper caps and put the 25 Ohms in series with rectifier (the metal one had been replaced).
Puzzled over VHF drive cord after refitting it. Not snapped, just off. A lever on piano keys engages AM or VHF drive cord to single tuning cord. AM cursor would jam. Cord was off the red flag of tone control, but not snapped. Fixed that after removing scale glass.
Refitted mysterious second small pilot bulb using a holder arrangement I'd not seen. Removed all the panel dust and refitted scale & knobs.
Powered up. No Glow on EM81, no hum. But more than 300V on an audio transformer pin.
Stared at chassis. Where is the 1300 Ohm resistor between audio transformer and secondary HT rail? Where is that transformer wire?
Remembered loose cut off burnt out resistor. About 1/2 way from one end was 700 Ohms. So the 1300 Ohms part. It MIGHT have connected to pin 9 on EL84 base. There is a tag with a yellowish wire on the fuse/voltage selector panel. Pokes and tugs here and there reveal it's from the audio transformer and goes nowhere else.
I fit 1K in series with 100 R from wire to secondary HT and now there is hum on Gram, loud if socket touched. Green glow at base of EM81. For a moment I'd thought the audio transformer was burnt out and it's got 4 connections on primary and a feedback winding.
No LW, MW, SW or VHF. Swapped EF89 and then ECH81. Don't think I've an ECC85 or EABC80, but maybe something else wrong as so dead. After 11 pm so no more tonight.
Maybe later on Saturday I'll look at it again and logically trace HT & IF.
The GB version I have https://www.radiomuseum.org/r/grundig_3d...w3dgb.html
The German schematic I'm using https://www.radiomuseum.org/r/grundig_2035ws3d.html though I already had it on the laptop from years ago from Dutch
