18-04-2022, 11:42 AM
I'm trying to fix a Mig welder wire feed motor speed control board. This one has a TYN 412 Thyristor which tests out OK. Further along the PCB is a series of surface mounted resistors which have numbers such as 122, 100 and 101 printed on their bodies, will they be the actual values of each resistor ? I have put my ohm meter across several and they test as the value marked on their body, but the track has so many other components associated with the circuit I though that I might be just lucky or confused. It is obvious that one resistor has failed and on its body it looks to be 220, I had thought of just replacing it with a 200 or 240. Any practical suggestions will appreciated. Ted
