23-03-2022, 05:33 AM
I'm in the process of installing one of these:
Emporia Smart Home Energy Monitor with 16 50A Circuit Level Sensors | Real Time Electricity Monitor/Meter | Solar/Net Metering https://smile.amazon.co.uk/dp/B08CJGPHL9...WGYBQ134C3
It's very accurate, typically within a very few % (some say 1%) of the utility meter. My configuration is different to the one I've linked to - I have three 200A sensors and 8 x 50A wide aperture sensors.
It's circuit-based rather than outlet-based as its intended to be installed in a consumer unit.
As we have a reasonably complex 3-phase feed to our property, I'm installing one in our meter cupboard.
This is more complex than a CU installation as effectively I'm having to make a small CU for safety reasons.
I like the architecture and it's, IMHO, very reasonably priced. The unit handles single or three phase utility feeds up to 200A and up to 16 x 50A circuits. It monitors voltage and current drawing its own power (40mA) from one of the phases. It uses your WiFi and the app is cloud-based. There's a range of different sensors, e.g. I'm using wide-aperture CTs as rather than clipping onto 2.5mm circuits in a CU, my CTs are having to fit 10+mm meter tails.
Fairly new to the UK - the company is very popular in the USA.
sıʌǝɹq ɐʇıʌ `ɐƃuol sɹɐ
ʞɔıu
ʞɔıu
