03-02-2022, 01:14 PM
I have a 8 cell battery holder that I want to use to hold 7 aa rechargables.
The 8th battery is really a piece of bamboo with a couple of drawing pins in either end and a length of 5amp fuse wire soldered to either end mimicking the battery connection.
The set up will be housed in a pp9 case and used to power my transistor radios.
My query is, is that 5amp going to give me much protection if there is a short?
I have been looking at wire ended fuses on the RS website and have seen these-
https://uk.rs-online.com/web/p/non-reset...es/7649457
https://uk.rs-online.com/web/p/non-reset...es/7649466
I was hoping these might have been ok but when looking at the specs I am a little confused as to wether I can use either of these.
I thought that it would be easy to use these wire ended fuses in place of the 5amp fuse wire.
