15-09-2021, 10:20 AM
(This post was last modified: 15-09-2021, 10:32 AM by peter scott.)
This recording shows the definition available for 405 line operation on VHS. The stability at the top of the scan is a bit wobbly but the drop-out performance of the old 3320 is pretty good. You will see that I'm cheating slightly with both buttons pressed in on the Sony 9-90 i.e. this is 405 UHF. You might need to select 1080 HD on your Youtube player settings.
Peter
Peter
