28-07-2021, 08:15 PM
Ever since I set up my external workshop (like a big insulated shed) I have operated 2 x small humidifiers (they run off 9v power supplies) which work a treat to keep dampness low all year round. They usually last a few years (they are left on 24/7) before a component like a fan fails/or the electric condenser pad (I cant think what its called?) so I will just replace the whole unit. However, one that I have now filled with water and I did forget about it so it switched itself off with a red warning light on. It was ok when I emptied and restarted it BUT I have just been outside and seen it half filled so i emptied but now it just continuously beeps with no LED on (I generally switch this off). In this instance, the unit is less than a year old so I don't understand why its not working?? Is there anything worth looking at at or just replace this one too?
