11-07-2021, 11:30 AM
Hi rescued this set from been put in the skip in 2013 for about £5 & when i got the set home & removed the back & the EL84 & EZ80 valves were missing so i replaced the EL84 but did not have a EZ80 but had a EZ81 & replaced C 65 on the 1301 trader sheet & i was rewarded with great reception on FM . Nothing on MW & LW only buzzing from the speaker & crackle when you turn the volume control been advised to clean the wave control switch which i did still no MW & LW .Is this a valve or a capacitor issue ? . As it is working great on VHF any advise would be grateful kind regards Bob
