27-04-2021, 06:26 PM
Hi All,
I must be getting old. I'm trying to use my old 2 panel tester to see if its still working but can remember 100% what the valve settings are? There is no setting for the negative grid volts and the anode & screen voltages comes from the AVT data section. If the Vf (filaments) the heater setting control from the VCM settings including the 1a/mA settings? Its been that long ago since I last used it.
Best Regards
Rob
Best Regards
Rob
