01-03-2021, 08:07 PM
My new polish telam ucl82 has a heater resistance of 80r (cold) and when in use I am getting a reading of nearly 55vac, on the pins, valve data says they should be 50vac.
My old mallard ucl82 when installed, the heater voltage was 50vac and its heater resistance when cold was around 71r
Can I run my new telam valve with that extra 5v increase safely, I take it the extra voltage is due to the higher heater resistance. All the other valves in the chain are all fine with regards to the heater voltages.
Danndad
Danndad
