13-01-2021, 04:30 PM
Hi.
I've another set here to restore. A careful examination on the set gave me no reason to think I'd land up in trouble, just the usual wax cap issues and out of tolerance resistors.
Well my hopes were dashed today and it reminded me of a previous 917. The dreaded B8G valve bases used in this TV. one base lost its tag with just a light touch. I only had one suitable base that was a used one with one with oddly one tag in half and the same pin!
So after drilling out the old one and replacing it plus checking the components around it it's now replaced. Then after taking the photos I see another in the same boat, the octal bases are also of poor quality and very flimsy. I had this issue with the other 917 I did and that one I believe is bereft of a CRT as it went down to air a few years ago. I might be able to get the set if the owner wishes to part with it for some of those things that you exchange for goods.
If I get stuck I do have a radio that I could cannibalise but that's a last resort. I do need to change the resistor on the new base as I've fitted a 12k instead of a 10k, definitely need to get an eye test again, some noticeable change since October 2020.
