27-08-2020, 10:48 AM
Quite a lot of modern and not so modern kit is covered with a soft touch finish. While this is nice when new it always seems to go horrible over time. My Evoluent vertical mouse had such a finish but fortuntely most of it has now gone, leaving ordinary shiny plastic which is fine.
I've just been given a simple slide/negative scanner that has a finish that's sticky to touch. It can be abraded off, though that also scratches the plastic. Rubbing with IPA seems to have no effect, though soaking, if possible, might work. Acetone will probably work, and dissolve the plastic too
Any ideas on how to deal with this nuisance?
