25-08-2020, 10:38 PM
Hello
Just to tell you that I'm still around, doing tests with those valves. I have obtained gains of x20 (Vout/Vin) in RF over 1Mhz, but I don't get gains in higher frequencies (> 20 Mhz). The very simple circuit, Vpp 50V, 1.3V filaments from a NI-MH battery, Anode to positive Vpp with an R of 20K, G3 to ground, G2 to positive with an R of 220K, G1 input with an R to ground of 100K. Some ceramic capacitors between G2 and ground and filaments. I've tried with the 1J24B, 1J29B-V and 1J17B. Measures are made with my dual trace osciloscope (Rigol DS2072 upgraded to 200Mhz), one probe on input (RF generator) and the other one conected to the anode via a small capacitor. All probes in high impedance mode 1/10X. It's posible that my valves are defective?
