23-06-2020, 10:22 AM
With the above Triplett came this mystery object; approximately three inches diameter. The indicator is a magnetic compass graduated +/- 90degrees. There are three wires attached and there is another hole in the wooden body so there may have been a fourth. The compass needle always points to zero on the dial so there is some ferrous material inside the unit. Any ideas what its function may have been?
Rod
Rod
