13-06-2020, 06:03 PM
This is the 2nd one of these 550w RS isolating transformers that I have (this is one I am using in the garden workshop). I've always had these wired with a 3amp fuse and its is connected to an a mk rcd twin 30mA socket in use. Since I have been using this recently for some refurb work (my WEM Custom 15) I have noticed that it will occasionally blow the fuse in plug without tripping the RCD. Does this suggest that I have a problem with the transformer OR just that the initial power input is just too much (connected to a valve amp) and causing the 3 amp fuse to blow? I've attached a pic of my set up.
Many thanks
Rob
Many thanks
Rob
