06-06-2020, 10:15 PM
I aquired these Philips 484 speakers with rotten roll surrounds a while back.
Last week I finally got them restored to working condition.
They sound much better than the smaller Kefs I've been using recently.
I bought the new surrounds and glue as a kit from a specialist shop in Holland, they are stuck to the cones and frame with a kind of special glue, a bit like bicycle inner tube repair solution. I think some people use a kind of PVA as an alternative.
The surrounds were fixed to the cones on one day, and then the surrounds to the frame the next day.
I fed a tone into them before the glue set to check they were properly centered but there was no problem of the cones rubbing the magnets, the coil spiders held them niceley in the middle without problems. I had had the glue for a couple of years, it had dried into a lump of rubber, I had to buy some more to do the job.
I'd put it off for far too long thinking it would be very difficult to get right, in the end it was quite easy. lots of advise on utube. there was no need to remove the speaker center covers. using some sticks to keep the cones away from the frame was a handy tip to help get the final glue in place before joining the two parts together.
Kind regards, David.
