04-06-2020, 12:52 PM
I've just found a few bits like this. This one measures about 70R between 1-3 and 2-4; about 2K7 between 1-2 and 3-4.
From the markings I assume it's a 2dB balanced attenuator for 600R audio circuits. Some are maked 2DB, other 6DB (all capitals, I know it's usual to write dB). A similar size device is white, branded PAINTON and marked 10DB, 600R, 1/8 WATT.
Also a couple of smaller red devices with 3 leads that are clearly from the same family. One is marked 75R 6DB which I think is self explanatory. The other AT1/75/6 which I suspect amounts to the same thing.
Anyone know where they were used? Does anyone have any use for them?
