18-05-2020, 05:15 PM
In the past when I've needed a lamp limiter it's always been a horrible bodge with a Safebloc, croc clips etc. So I built a fairly posh one using only bits from the junk box. It's not a thing of great beauty (the box lid is very secondhand but you can't see it) and the internal wiring is adequate rather than lovely but it works just fine and is safe.
It's got 40W, 60W and 100W lamps, obviously easily swapped for special requirements. Input and output are IEC 3 pin connectors because I hate captive mains leads. Labels are printed paper stuck on with PVA. I ought to out some varnish over them to keep them clean.
