30-12-2019, 09:30 PM
This used to be a routine problem in southern England in the days of analogue TV. Casued by high atmospheric pressue and temperature inversions. It was even worse in the days of VHF 405. With digital TV I thought this was all in the past but I was wrong: https://www.bbc.co.uk/news/technology-50945421
I haven't seen the effects, but like most digital problems I suspect there's a very fine margin between working perfectly and a complete mess.
When designing any transmitter network the engineers have to make assumptions about propagation and weather. If you design for everything to work come hell or high water then you've probably restricted the number of channels you can use. If you allow for too much network capacity then the wrong kind of weather will cause trouble too often.
I wonder if the relinquishing of Band V has made things worse.
