16-11-2019, 10:20 AM
I was wondering if there is a simple way to make an RDS display add-on for an FM radio that doesn't have this feature ?
I assume that you'd need to extract the sub-carrier required, process it in some way then use e.g. an Arduino or similar to decode the data and send this to a 16x2 line LCD.
Either this or a module that does it all for you.
I know you can use a computer running the appropriate software plus an RTL dongle but I'm thinking about a smaller, low-power solution that could be added to an existing FM receiver.
Andy
Andy
