07-06-2019, 04:32 PM
(This post was last modified: 07-06-2019, 04:33 PM by Diabolical Artificer.)
After rootling out some bits I decided to have a go at knocking up a preamp to go with the big amps I made. They need 1.5v RMS to get the full 100w OP, my PC and other music sources do a bit less than this, so the preamp will compliment them.
At first I was thinking of designing the circuit myself, maybe using EF80's triode strapped for a line level amp, but after some searching online I decided to use Patrick Turners design's for the phone and line level amp, the fettling will take enough time as it is, so decided to use an existing design. I have a lot of respect for his work, he put in a lot of research and testing and to be honest a phono amp is a complex beasty, anything I designed wouldn't be half as good as his.
I've had this big tfmr and choke knocking about for ages, see pics. The tfmr is huge in comparison to it's power output, only 80mA, so perfect for a preamp. I've connected it with an LC filter rather than CLC, to reduce the HT, with two 820u 400v caps ripple is 20uV before regulation. I'll use Patricks PSU design as a guide and fit it what components I have.
Any ideas and constructive criticism welcome, Andy.
