24-02-2019, 04:45 PM
I am thinking of embarking on a model train hobby. My son seems keen and has come up with some layout plans,
the wife has also shown interested in the idea.
I am using a 3 circuit train controller made by my brother in law back in the early 90's and I discovered recently a problem with reverse voltage by the wrong operation of points damaging the home made 3 circuit speed controller, which is based on LM317 modules. (I think they are the 1.5A LM317K types)
I think the main problem was caused by the tantalum capacitors, which were originally used when the controller was made back in the 90's. They liked the reverse voltage less than the LM317's and they blew their tops off and took one of the bridge rectifiers with them. The LM317 was OK.
Can you please comment on the suitability of using PPTCs, namely the 0.5A 32 volt type see here. https://www.littelfuse.com/~/media/elect...et.pdf.pdf .
Where is the best place in the LM317 circuit to fit the poly fuses, before the rectifiers, before the IC's or before the fwd/rev switch. Will the added cold resistance effect the motor torque much.
Can anyone suggest a simple alternative to prevent reverse voltage problems?
Thanks
Mike
Thanks
Mike
