17-02-2019, 11:43 PM
I was about to do a quick repair using a hot melt glue gun and suddenly discovered that it had what looked like a badly wired plug with the cable pulled part of the way out of the grip saddle.
When I looked more closely the silicone rubber cable had gone all sticky and soft close to the plug while remaining normal along its length.
Once I had removed the plug it was obvious to me that the rubber had rotted most where it contacted the nylon grip saddle. The part that was in contact with the plug body was far less degraded.
These two plastic materials obviously react so If you have mains powered kit with silicone mains cables make sure there is a sleeve fitted under the cord grip saddle.
My estimation based on the age of the glue gun sets the rate of migration of the decay from the nylon into the flex insulation to be about 1mm per year.
I would advise you check your silicone mains cables and fuses in order to save yourself a rood awakening. It is class II so the RCCD will not stop it going BANG if you fail to spot this problem.
I did fit a 3 amp fuse before using it again.
