14-02-2019, 12:08 AM
The selenium HT rectifier in my Roberts R 66 battery mains portable has failed. I have read that this can be replaced with a 1N4006 diode and a 100 ohm resistor in order to give the correct HT half wave rectified DC voltage. Three questions.
What is the correct HT voltage?
Where exactly in the circuit should this be measured?
What wattage resistor should be used?
Thanks
Lynton
Thanks
Lynton
