24-01-2019, 09:33 PM
Let's fnd out what a 405 line picture looks like on this 24" 405 line TV set?
Took delivery today of this unique 24 " CRT console TV set. The set is a Kolster-Brandes PV100 in which the chassis has been installed into a specially made console cabinet. The seller told me that the set was purchased in 1958 by an American Gentleman who lived in Kent.
Before any attempt is made to power up the set the line output transformer will be warmed up to drive out any moisture. The method used to do this has been discussed in vintage TV forums. A current of 20 to 30 mA will be passed through the EHT overwind and primary winding.
The chassis of the PV100 is nothing special being simply a modified version of the popular OV30 model. The 90 degree magnetic focus CRT is a Brimar C24KM which was imported from the Continent. It has a pentode gun so it's likely it was made by Philips or Telefunken.
The line output valve is the Brimar 50CD6G, the valve with twin heater-cathode assemblies. The common PL36 can be used as a replacement as long as an 83 ohm resistor is inserted in the heater chain. PL36 has 25 volt heater.
The cabinet is solid and beautifully made only let down by the awful pegboard back.
Geordie McBoyne.
Geordie McBoyne.
