07-12-2018, 06:48 PM
Is there a way of simulating slower speeds?
I know that many would like to speed it up but this is a serious question!
Our daughter is moving into a new flat. In her existing flat she has Virgin Media internet and, of course, gets very high speeds.
But VM don't serve the block she's moving to, so she will be at the mercy of whatever she can get over a BT line.
BT say 'up to' 60 Mbs.
Her problem is that VM's entry level has gone up over the years from 50 to 100 and now 200 Mbps and now she is faced with a range of different speed offerings, she hasn't a clue how much bandwidth she actually needs.
So I was wondering if there is something she can install on her PC that can be set to simulate a range of speeds.
My idea is that she could then set it to simulate the lowest speed of all the packages available and see what happens when she uses her PC normally. If she has any problems, she can reset it to the next higher level and so on.
Having discussed her usage with her I think she would be happy with quite a low speed but, having experienced appalling speeds where she works (because it is in the country and a long way from civilisation) she is concerned that she might either choose a package that doesn't suit her needs or opt for a more expensive package than she really needs.
