04-10-2018, 07:36 AM
(This post was last modified: 04-10-2018, 07:37 AM by Radio Fixer.)
I have a pic which you should be able to scale dimensions from.
If the radio is slightly unstable on its own frame aerial (OK on an external) try a grid stopper in the IF amp. I found a top cap that would mount the resistor. Note that other later valves have these so I suspect the set had a tendency for this.
Gary
Gary
