I am having a problem with this little RGD R135 radio I recently bought off Ebay.
It was described as screws missing from back. The screws fixing the chassis to the front half of the case were also missing.
The radio only seems to work on FM and that is very very faint.
I have fed an audio signal into the volume control and the audio side seems to be working OK, so I believe the coils and trimmers have probably had a very bad case of twiddling.
Someone has also had a go at fixing the tuning dial cord but not done it correctly as it was not possible to get the full range from one end of the dial to the other.
That's now fixed after a lot of experimentation.
There is not a lot information that I can find on this RGD radio but I have at least got a 2 page service sheet.
I have discovered that despite its appearance the RGD R135 appears to have the same chassis as the early ITT Colt.
There is not much information on the ITT Colt either, but I should think that the RGD R150 is pretty close in alignment procedure if not circuit and layout..
So my problem is I am not very experienced in FM / AM sets and circuits and I am trying to identify the various coils.
So from the circuit diagram I think the coils are as follows;
FM RF = L302
FM Osc = L304
FM IF1 = L305
FM IF2 = L308
FM IF3 = L311
FM discriminator = L312
AM Aerial = L306 & L307
AM Osc = L315
AM IF1 = L309
AM IF2 = L310
AM IF3 = L313
I was wondering if somebody could please confirm the above inductor list and their use.
Thanks
Mike
FM RF = L302
FM Osc = L304
FM IF1 = L305
FM IF2 = L308
FM IF3 = L311
AM Osc = L315
AM IF1 = L309
AM IF2 = L310
AM IF3 = L313
Thanks
Mike
