05-08-2018, 06:42 PM
Hi All
I hope you are all enjoying the hot weather.
I recently bought this signal generator and its not in the greatest of condition and of course it doesn't work. I will lay money that the OC171 will be kaputt although I have some AF178 which I believe can be used as a direct replacement.
I stripped it down in the workshop today although the 30+ degree heat did get to me a little.
i am a bit concerned about earphone addition which doesn't seem correct.
Rob
Rob
