A reference in a recent thread about replacing a screen decoupler in a TV IF stage reminded me of this, which I first wrote up many years ago. I don't know if this is the best place for it but I can't find a 'Handy Hints and Tips' forum. Mods, please move it if you think it would be better elsewhere.
Small decouplers in TV and FM IF strips of valved equipment are awkward to eliminate from suspicion although all that is usually needed is to bridge each one with a known good one. But trying to hold a small component in place when there are two wires about 10mm - and 200 volts! - apart can be tricky, particularly when you need to use the shortest possible wires. I made up a little tool for checking these little beasts many years ago and it paid dividends over the years.
All you need is a scrap of wood (mine was a glue block from an old cabinet), two panel pins and a 0.001µF ceramic capacitor - tubular for preference.
Knock the pins into the end of the wood block - the spacing should correspond to the PCB spacing* - you might have to need to place them on the diagonal, dependant on the size of your block. Cut off the heads with cutters to leave two points about about 12mm long, then solder the cap between the two pins. Now you can shunt with immunity to shock!
* Of course, it works just as well in a wired chassis!
