25-07-2018, 08:01 AM
The speed change control in a 6-300 deck on which I'm working is jammed in the 33.333rpm !2" position. I presume, as with all old record decks, that the trouble is caused by dried grease, but it appears to me that the complete mechanism would have to be removed from the deck plate to clean & re-lubricate it. The only part I've been able to clean is the trip pawl. I can't even see which part(s) arre stuck without disassembly. Maybe someone familiar with the Unimech decks can advise me as to how to proceed.
