03-07-2018, 11:29 AM
(This post was last modified: 03-07-2018, 11:41 AM by ppppenguin.)
We're refitting our kitchen at the moment using Ikea units. THe cooker hood has a 3 speed extractor which is horribly noisy. I reckon all cooker hoods are far too noisy so the obvious answer is to get an external fan and remove the fan in the hood. So far so good.
It would be nice to use the 3 speed controls in the hood to work with the external fan. I don't think it's possible but please let me run it past you all.
The fan in the hood has 3 taps on the motor which is of unknown type. The resistances all add up sensibly so I'm pretty sure it is actually 3 taps. The external fan has a capacitor, not sure if it's start or run, on what look slike it could be a motor with an external rotor. So definitely no direct compatibility.
The external fan didn't like a dimmer switch very much. The speed wandered up and down when set to half speed. Possibly a trailing edge dimmer would do better. A variac worked fine but is not a practical solution. Can I do anytihng by switching different capacitors? Or any other ideas?
PS: The fan/motor in the external fan is made by Blauberg BL-B190A-2X-A01-01 rated at 60W. USes a 1.5uF 450VAC cap.
