27-05-2018, 09:18 AM
After my recent PC problems I decided that having a bootable clone of my C drive would be a very good idea. A lot easier than doing a clean instal. I should add that all my own data is on a separate drive which I routinely clone for backup and this works fine. The problem is making a bootable cloned drive.
I thought the problem might be with Aeomi Backupper which I've used for cloning until recently. So I tried the free version of Macrium Reflect as recommended here: https://www.howtogeek.com/199068/how-to-...r-an-hour/
I made a clone with Macrium Reflect and it wouldn't boot. So I tried my W7 instal disk (the same one I used to rebuild just a few days ago) and when I tried to repair it said that it was the wrong version of Windows. I also tried the rescue CD I'd prepapred using Macrium Reflect. This offered to repair the C drive but it still wouldn't boot. "Boot selection failed because a a required device is inacessible".
At least I'm doing all this at my leisure, not under the stress of having a non-working main PC. I should add that I'm attaching the cloned C drive to the same connector as the normal C drive so the BIOS shouldn't get confused.
What am I doing wrong?
