03-02-2018, 09:22 AM
Having identified several faults in this PSU, replacingl parts as requitred, including several electrolytic capacitors and a s/c schotky rectifier diode in part of the circuit which supplies + & -7v DC to the amplifier board, I powered up the PSU only to find that there is no DC at the point which supplies an estimated 50v (The smoothing caps. on this point are 470u/63v) to the amp. I'm puzzled. This DC supply is derived from a transformer fed from the incoming AC mains via a bridge rectifier and two smoothing caps. There is ca. 340vDC across these caps., but the voltage being fed to the aforementioned transformer fall to very low levels (<3 or 4v) after less than a minute. THe associated transistors checkout OK 'cold', but I guess they could be breaking down in use. Other parts, including the transformer in question check out OK. No spares or service info. seems to be available for the 'Beatbox', which doesn't help. I've traced out most of the circuit, which uses a TL494 DIL IC, but haven't drawn it out in a suitable form to post. Maybe I should just replace the transistors in the primary circuit and see what happens?
