26-01-2018, 01:06 PM
About six months ago the picture disappeared on my HMV901. The focus voltage was all wrong so it was fairly obvious that I would need to get into the focus chain and fix it but unfortunately it's in the most inaccessible place on the underside of the power supply chassis. There is no access from the bottom of the cabinet so you need to disconnect the mirror lid prop, take out the screen frame, remove the CRT and its supporting cradle, remove the timebase chassis, loudspeaker and sound chassis and only then can you lift out the very heavy power supply.
![[Image: hmvback2.jpg]](http://www.nostalgiatech.co.uk/hmvback2.jpg)
I replaced most of the focus chain but not the resistors I had replaced many years previously then reassembled the set. Then at the back end of last year the picture disappeared again and just yesterday I went through the above procedure again and tested each resistor in the chain only to find no fault!
After reassembly I measured the CRT voltages and discovered that EHT, focus and accelerator voltages were all fine. The cathode was 36 volts above the grid,
in a tube with 20 volt cut-off.
Looking on the bright side I'm getting quite good at dismantling and reassembling the set.
Peter
in a tube with 20 volt cut-off.Looking on the bright side I'm getting quite good at dismantling and reassembling the set.
Peter
