19-01-2018, 09:54 AM
How can these devices be tested with conventional instruments.? I suspect a faulty I.R. receiver in a Pioneer AV rreceiver, and, checking the 3-terminal device out of circuit witha DMM is, to me, inconclusive. Using one of those Chinese multi-component testers, the device in question, a GP1U27X, reads like two back to back diodes between pins 1(Output) & 3 (Ground), with corresponding diode readings between pins1 & 2 (Vdd) or pins 2 & 3. The associated remote control checks out OK using an I.R. remote control tester, and the circuit to which the I.R. receiver connects (basically a 2-transistor switch) checks OK, with +5v being supplied to it. No doubt the easiest way to prove whether the I.R. receiver is faulty is to get and fit a new one, which I may do. All functions of the VSX-808RDS work, btw, but operating the remcon has no effect whatsoever.
