15-11-2017, 08:57 PM
I've completed the restoration of a Ferguson 901AC radio set.
When first placed on the work bench it was found the set did work but not very well. The 901 was made in 1939 and was one of the first Ferguson radios to shed the American design influences. Three European valves are employed in the receiver chassis, Mullard ECH3, EF9 and EBC3. The separate output and power supply chassis employs a 6V6 and 5Y3. First examination of the chassis units revealed that coupling capacitor between the AF amplifier and output valves is located on the power chassis and as expected it was leaky. Well, it seems that a previous repairer was aware that the capacitor was faulty but instead of replacing it, instead, the cathode bias resistor of the 6V6 was increased to 1000 ohms and the bias bypass capacitor replaced with a great big 32microfarad 500 volt electrolytic capacitor. A very strange solution to effect a "repair".
The offending components have been replaced and the result of these efforts is an improvement of the sound quality.
But the set is still insensitive. The valves are OK and voltage readings are about right for this model. A service sheet was obtained through this website so now full alignment can begin. This is a very well designed receiver and all the necessary adjustments can be carried out from the top of the receiver chassis. Start procedure. Tuning pointer correctly positioned on the scale. Peak up the IF transformers on 470Kc/s. The service notes inform us to start adjusting the short waveband first: tune the signal generator to 16Mc/s to adjust the oscillator aerial trimmers in that order. Signal generator reset to 6Mc/s and adjust the padder trimmer VC3. Recheck tuning scale calibration.
A similar procedure is used on the Medium and Long wavebands. HF end of the waveband adjusted first followed by the padding trimmers VC6 and 9 to adjust the lower frequency end of the MW and LW wavebands. The calibration of the LF end of the Medium Waveband is confirmed by checking that BBC Radio 4 on 603Khz comes in on 500 metres.
The attachments show the trimmer positions and frequency adjustments.
Excellent results on the medium waveband. Not so sensitive on the short waveband.
The cabinet needs attention to in some parts.
Geordie McBoyne.
Geordie McBoyne.
