27-09-2017, 12:40 PM
Another bargain I couldn't resist.
Credit to Fraser on the EEVblog forum for spotting this.
An interesting 'scope that uses a PC / Android / IOS device as the display.
Connection is wireless and it's powered by a rechargeable battery so it should be great for floating measurements.
Not the latest and greatest but for £20...
Specifications
- Input range: 5mV to 20V/div (12 steps)
- Timebase: 1µs to 1s/div
- Max. 30Vpp input
- Real time sample rate: 2 x 10MS/s
- Input impedance: 1Mohm
- Input coupling: AC+DC, AC and GND
- Bandwith: 2 x 10MHz
- AD resolution: 8 bit
- Sample buffer: 4K/channel
- Consumption (battery): 160mA (max.)
- Battery: Li-ion 3.7V 1800mAh
- USB charge current: 5V/500mA
- Max. weight: 180g (0,39lb)
- Dimensions: 100 x 100 x 35mm / 3.9 x 3.9 x 1.4”
Minimum system requirements
iOS (*)
Android™ 4.0 (*)
Windows XP or higher (*)
Tablet or PC
Jim
Credit to Fraser on the EEVblog forum for spotting this.An interesting 'scope that uses a PC / Android / IOS device as the display.
Specifications
- Max. 30Vpp input
iOS (*)
Android™ 4.0 (*)
Tablet or PC
Jim
