22-09-2017, 10:36 AM
I have found that many VDRs use colour codes that vary quite a bit.
These ones look like it reads Top Dot Band using my own judgement based on the fact that that the early 1970s transistors close by will most likely be rated at 30 to 50 volts.
Red white black being 28 would make it 28 volts.
Is there a magic answer or are they like capacitors?
