24-08-2017, 05:54 PM
Hi.
I have had a CR100/B28 receiver for many years, It has no cabinet although I obtained a B28 front panel a few years back with the little plaque declaring that it was built in 1952
The set had been quite heavily modified before I got it with the original double RF stages comprising 6K7G's removed and little EF95's fitted on a new piece of alloy plate. The gain was astonishing but impossible to align with lousy tracking, images and cross mod to spoil the tremendous sensitivity.
I gave up with it around three years ago and it was put aside. It also needed rewired in some places, the socket on the back was bare with Mains and HT present which was a hazard, I'd already replaced some caps but more were in need of replacement. The set actually is around 1942.
I pulled the set out yesterday and so far I have removed the B5 socket at the rear, replaced the worst of the rubber wiring and will be fitting a Bulgin plug and socket for the mains that is a perfect fit in the recess the B5 socket was mounted on.
I really could do with a circuit for the set so I can compare the original to the mods done to the RF stages.
Watch this space.
Watch this space.
