21-06-2017, 10:08 AM
Apologies if this isn't the right place for this but I couldn't think of anywhere else.
I need some help here!
I was reading through this thread over at uk.tech.digital-tv in which Dan is asking about the importance of fitting the terminator provided when he disconnects his VM Broadband internet feed.
Being usenet, the conversation wandered all over the place but no attempt to answer the original question! So Dan asked again, to which I replied:
"The reason it is required is simple: the band of signals coming into your house is split. The majority forms the downstream for all the TV muxes and the internet and it is easy to provide plenty of isolation to prevent interaction with other customers' feeds.
The remainder is for the upstream and is used by your modem to communicate with the router in the headend or hub. All page requests and emails are sent using it and anything else you upload, whether it be pictures, mp3 file, VOIP or video.
All of these upstream feeds are combined to feed the input of the router and any external interference entering an unterminated feed can severely degrade the service for everybody by making it difficult for them to communicate with the internet.
Effectively your unterminated feed will become a receiving aerial, injecting local interference, short wave radio, baby alarms, etc. into the network.
A number of unterminated feeds can severely escalate this problem very quickly so yes, that terminator is very important.
To which Tweed replied, not unreasonably: " How does an unterminated coax act as an antenna?"
May answer - and note particularly the first few words! - was "Probably needs a better brain than mine to give a detailed explanation but I've noticed this: "a transmission line with a high SWR tends to act as an antenna, radiating electromagnetic energy away from the line, rather than channeling all of it to the load" in:
https://www.allaboutcircuits.com/textboo...resonance/
Except for the signal direction, there is no intrinsic difference between transmitting and receiving antennae.
Monitoring the return path feed in a CATV headend with a suitable receiver can be very enlightening to anybody who doubts this ...
There seems to have been a fair bit of opposition to my explanation, including my last comment regarding the differences between transmitting and receiving antennae (which totally ignores the fact that, in this case, the 'transmitter' has an output frequency range of 85 - 750MHz!) so, do we have "a better brain than mine" to bail me out here ...?
