21-05-2017, 05:59 AM
A while ago the "rectifier" on my motorbike, a 94 Yamaha XV535 virago, died. As a new Yamaha part is about £100 I got a cheap jobbie off ebay. Went to start the bike yesterday, battery flat, thought I'd forgotten to turn it off. Charged the battery up, started it, got 50 yards, battery dead. There was a short between - and + which turned out to be, you guessed it, the rectifier. One diode was shorted.
Looking at the bikes electrical system in more detail, AFAIK the alternator is three phase, havn't had it on the scope yet, but the schematic shows three windings in a Y shape. I took the original "rectifier" apart, which was potted. It is basicly three diodes on a heatsink. So as diodes capable of handling a few amps at 12v are cheap, why not make my own rectifier?
Again looking at this in more detail, the bike "PSU" has no smoothing cap, but does have a regulator, which from the size of it is probably nothing fantastic. So I'm thinking why not pop a big cap after the rectifier and maybe build a better regulator too. The old "system" is crap. The connector from the rectifier to the battery is burning out, being one of those multi horrible spade connectors. I've already had to replace the LH coil twice and the TCI and solder the coils to the loam as the old spade connectors were loose dirty etc. An up rated charging/supply system would e the way to go I think. Bike electrics are pretty basic and horrible in comparison to the PSU's we use on the bench or even in basic consumer gear.
Any thoughts, much appreciated. Andy.
