09-05-2017, 06:18 PM
......That keeps needing to revise old ground. I find I tend to forget stuff that 3 months ago I had well understood. Last night I had to go over FM all over again as it had all gotten murky. There is a saying of Einstein's I liked a lot when I heard it quoted. He said if you can't explain something technical to a cleaner so it's understood, you haven't understood it yourself. I think being a teacher, this would have been clear to Einstein as you really need to be clued up to explain to others. Anyway, I sometimes think I have something truly sunk in and then I may be explaining myself. And at that point I think, "Hold on a bit, now this seems a bit wobbly." Another thing I forgot recently was how to work out the value of a cathode resistor by first referencing the current and voltage bias required. I had to revise it. So tonight, after plumbing my boat all day, I will further revise FM modulation.
